Clutch Replacement Time
Originally Posted by MTP04,May 27 2009, 09:54 AM
O'malley, Can you explain what this is?
Originally Posted by Redline Junkie,May 27 2009, 10:07 PM
the clutch safety swith he is talking about is the switch that is pushed when you push down on the clutch pedal to start the car. you should disconnect this switch and put a jumper wire in when installing a heavy duty pressure plate. just remember to take your car out of gear before pushing the start button!
Isn't it just used to make sure the car doesn't leap forward when started since you park a manual car in-gear?
yes, but when installing a heavy pressure plate, as you press the clutch pedal in to start the car, all that extra force from the heavy press. plate is transfered to the crank shaft which in turn puts too much sideways force on the sides of the crank shaft counter weights and connecting rods especially when there is no oil present before start up, it could cause some serious damage to your bottom end. there have been cases leading to "crank walk" in the past. there is a thread about it in the main forum garage section.
Originally Posted by o'malley_808,May 29 2009, 03:52 AM
^couldn't have said it better. And people thought I was crazy when I put I diy on how to do this earlier this year in the southern Ontario forum
