What to do?
What to do?
Ok, My car is at the dealer right now because of the clutch buzz. The dealer is going to replace the bearing but they will not replace the clutch because it is a wear item. My car is an 02 with 34000 miles and its certified.i have 2 questions. shouldnt they change the whole clutch and bearing? and if not..should i buy a new clutch and have them put it in while the tranny is down?
I thought the buzz was only a MY2000 problem that was fixed by stronger springs or something. replacing the bearing shouldnt mandate a new clutch, but it would probably be cost effective as long as its out if your car has high miles, or if the clutch was used hard at all. No use in doing it and throwing away a good clutch if it was babied though IMO.
make sure the problem is the bearing and not anything else though
