South Florida Owners from South Florida
Help a brotha out!
Old 07-30-2007, 04:16 PM
GranPrix's Avatar
I know exactly what the problem is..
..your S noticed you were putting fogs on it and now she's trying to tell you to take that sh.it off of her!!
Old 07-30-2007, 06:43 PM
DRE.'s Avatar
the problem seems to be with the relay. I checked everything out and that seems to be the only cause.
Andres
Old 07-31-2007, 05:28 AM
GranPrix's Avatar
Originally Posted by notamaster,Jul 30 2007, 03:51 PM
First check the wires at the relay plug . You shold have 1 ground , a constant power , switch power in and output. There is almost allways a small diagram on the relay itself to help out. First get you test light and unplug the relay. Test is there is signal fron you switch to the switch power at the relay. Next make sure that the output wire is not grounding out going to the lights themselves. With the power wire to the lights removed you could make sure the relay works if you here it click when you turn on the power. If the lights falsh for a spit second before the fuse blows that sounds like you might have a wire crossed at the lights
Old 07-31-2007, 05:35 AM
S2KSuzuka's Avatar
First, you should be using a bosch relay, the rest are all crap.
next the wiring of the relay is very important.
a relay needs a ground and a hot to trigger. start there disconect the main input power and output to the lights and see if the relay clicks when you flip the switch.
if that works the relay works.
then from the diagram that should be on the side of the relay, hokk up the input power form the battery, and the output to the lights.
Oh, put the relay where you can access it with the bumper on, the engine bay is a good place
if you have the car at the meet on sat, I can take a look.
Old 08-01-2007, 09:33 AM
McMuffin's Avatar
hey did you get that worked out. i got mine in and had minimal problems.
User 71524
12-27-2010 10:14 AM
DRE.
07-31-2007 09:17 AM
leo520
06-08-2007 06:41 PM
Thistler
08-19-2005 09:45 AM
tomspedale
09-14-2002 04:17 PM
Quick Reply: Help a brotha out!
