Dent Removal
dude, I heard that those places (sometimes) put a hole and plug it up in order to remove the dent. Until I find out how they really do it, I ain't going to those places. Anyone have knowledge in this field?
They will have to drill a hole if the panel they are trying to access can be reached from behind, when they did my quarter, they drilled a tiny hole in the underside of the wheel well, and then plugged it up after with a rubber plug.
Sadly, the guy I used, vanished from the face of the earth. I will keep watching this post.
yeah, the only place they should need to drill a hole is in the rear quarter panel, because they will need to get behind it somehow. In that case they just drill through inside the wheel well, so you will never see it.
Most shops should let you watch as they take care of your car. They just go in behind the panel with a series of tools and push out the ding.
lets bring this up again as i have a crease mark where at the bottom of the rear quarter panel where is just in front of the rear wheel above my side skirt, they guy told me that he will need to drill a small hole to get the leverage but i already saw there is a hole there which is is a factory hole but he said is too far???is it what he said is true or he is just being lazy???
Originally Posted by GranPrix,Feb 27 2007, 10:06 AM
I need an good dent removal shop/person...any1 know?
7862951740
he had to make a hole in my door too because there is a safety beam that he cant get to through the window.
