Broken Bolt
Broken Bolt
Here is the are where the bolt is broken off. I can't get a pair of vice grips or anything since it broke off under.
Here are the bolt extractors I bought.
Not sure if this will work fine or if it'll make the problem even worse. Just looking for suggestions before I dive in head first.
Maybe someone here has a kit they use that wouldn't mind helping me out >.> ; I could pay you in beer or pizza lol.
I once had a bolt incident.. and fyrestrike and prospect s helped me out using an "ez out" or something like that...
Actually..
Ez out
hammer
torch
and hours and hours of dedication...
Thanks guys!!!
So.. ask Fyrestrike and Prospect S
Actually..
Ez out
hammer
torch
Thanks guys!!!
What you picture are a set of easy outs, but Daworm is right about the patience. What you need to do is to drill a hole in the center of the bolt and tap one of those easy outs in and try and reverse the bolt out. Be very careful as I have had a long time ago a easy out break inside the bolt and that is a real issue as they are hardened.
What you pictured you might try and take a dremel and put a slot into the head of the bolt as well and then use a impact driver to loosen it up enough to back out. I would soak it first in penetrating oils either way.
good luck
good luck
Vinny_GPW-S2K
06-28-2014 05:55 AM
Bret
12-10-2003 07:43 AM
