Mark this thread as Unsold
Help Transmission
If it was the clutch fluid than most likely your Master cylinder needs to be replaced. From the drivers side floormat trace the clutch pedal up to the firewall. I bet you see some clutch fluid and/or sludge there. They go out quite often. Topping it off is only a band-aid fix.
