Mark this thread as Unsold
Help Transmission
Help Transmission
When i am at a dead stop i have to use all my force just to put it in gear and putting it in reverse is nearly impossible, but once i am get it moving its fine, the shifter slides into all the gears just fine. Does any one know what might be wrong or know of a cheap transmission shop? I am using Honda OEM transmission fluid, just changed it 3k miles ago.
I have a feeling this guy has air in his clutch lines/or a leaking slave cyl or just really low on brake fluid...I had the same problem with my S it wouldn't go to gear due to the clutch pedal being just limp
