Mark this thread as Unsold
FS: SPC Camber Joint, 255/40R17 Dunlop Z1 Star Spec, Colgan Car Bra, Test Pipes
First Name: Nam
Price: All prices are OBO, but I believe they are already aggressively priced.
Contact: Please PM or E-mail
SPC Performance Camber Joint - $100
Like the title says, I have the SPC Performance Camber Joint. I tore the dust boots from the camber joints during the removal, but it should be easy to replace and cost about $5. Otherwise, it is in good condition. It gives you an additional 2 degrees of negative or positive camber. This is perfect for track junkies on OEM suspension who want additional rear camber for better grip and tire wear, or for lowered daily drivers who want to add back positive camber to get more even tire wear.
Two (2) x 255/40R17 Dunlop Z1 Star Specs 50% tread remaining - $75 picked up for both
Free with purchase of a set of wheels above.
Colgan Car Bra for AP1 - $75
Carbon fiber pattern. Made for AP1 without the OEM lip. Has hole for front license plate. Has optional side mirror covers. Great condition. Small cut in it to put in a tow hook, but is very difficult to see unless you look for it.
Test Pipes - $50-$75
60mm Test Pipe ($50) - inner diameter matches almost exactly with that of OEM exhaust
63mm Test Pipe ($75) - inner diameter slightly bigger than OEM exhaust, better for aftermarket 63mm exhausts. Has flanges to mate with catalytic converter heat shield for the stealth look
70mm Test Pipe ($50)
O2 Fix ($20) - Remove the CEL when using these test pipes
Thanks!
~Nam
Pictures of the Z1 Star Specs
Thanks!
~Nam
Update: I took a closer look at the track trunk, and it looks like the only holes it has are for the Voltex wings and the S2000-specific APR wing. The holes for the APR GTC-200 are covered up by the black matte vinyl, but it would be plug and play for either a Voltex wing or APR wing.
Pics are coming soon.
The WedsSport are currently semi-pending to LickMyWalker, based on logistics. If the deal falls through, I will post pictures of the 949. They are in better condition than the WedsSport, as they have only been used for 8 track days and to and from the track.
