Mark this thread as Unsold
FS: CD player i-Pod ready 4volt preamp
Cleaning out some space.... all items are priced low for fast sale. I can bring any of these items to TopDown's Friday meet in West Covina.
1. Kenwood Excelon KDC-X591 CD/MP3/WMA/AAC Receiver i-Pod ready (need cable) $110.00
4Volt pre outs!!!! Very important feature!!!! Built in X-Overs, Great sounding unit!!
Features:
* CD player with built-in MOSFET amplifier (22 watts RMS/50 peak x 4 channels)
* Plays CDs, CD-Rs, and CD-RW discs, including discs loaded with MP3, WMA, and AAC files (will not play Digital Rights-protected music files on disc)
* Detachable, fold-down face
* 24-bit digital-to-analog converter
* System Q EX Sound Control (6 EQ curves and a 3-band parametric equalizer)
* "Supreme" audio processing for better sound from your compressed music files
* Speaker settings that allow you to tailor the sound to the size and type of speakers in your car
* System E's+ high- and low-pass filters
* Rear USB and auxiliary inputs
* Optional connecting cable gives you iPod control (uses both the USB and aux inputs)
* Compatible with Kenwood's Bluetooth adapter
* Compatible with Kenwood's iPod control adapter (in case you want to use your USB or aux input for something else)
* Satellite radio-ready (XM or SIRIUS tuner, service subscription, and antenna required)
* HD Radio tuner ready
* CD changer controls
* Three sets of 4-volt preamp outputs
* CD frequency response: 10-20,000 Hz
* CD signal-to-noise ratio: 110 dB
* FM sensitivity: 9.3 dBf
2. MY06 Radio door assembly rated 9.8/10 (no scratches just used) $50.00 **SOLD**
3. Radiator Cooling plate (generic brand) $30.00 **SOLD**
4. Hella Optilux 1100 Projector driving Lamp Kit $30.00
All kits feature die cast metal housings, 55W H3 bulbs, and glass lenses which ensure long life and durability. Deluxe wiring harnesses along with relays and switches are included with trilingual instructions. This projector fog lamp system features a 40mm projector lens and a black die-cast metal housing. The high intensity, focused beam increases visibility in all driving conditions. Includes two die-cast metal housing fog lamps, heavy duty mounting brackets and hardware, illuminated switch and deluxe wiring harness with relay and fuse. Dimensions: 2.8 W x 4 D x 2.64 H. By Hella.
Features:
Originally Posted by dragtek,Apr 22 2009, 05:03 PM
hey, bring the cooling plate to Topdown and ill take it! how does it fit? see u then!
ill pick that up
ill pick that up
smurf2k
07-20-2006 05:47 PM
