Mark this thread as Unsold
fs: CA 02 ap1 f20c motor
First Name: solo
Price: 700obo
contact: 626 9228374 txt or call
02 ap1 motor
80k miles on it
comes w/ head and block, has never been pulled apart, no accessories included
Price: 700obo
02 ap1 motor
80k miles on it
Not really... The head is usually undamaged from a spun bearing. The pistons still seal to keep any debris from making contact with the head. The oil may get some contamination from the bearing material but usually it's not enough to damage the head.
A spun bearing can potentially damage the crankshaft, but some times it is savable depending on how long the car was run with the spun bearing and how lucky you are. The crank is made of a harder material than the bearings, and some times it is okay. A spun bearing does some times scar cylinder walls because it's changing variables in the stroke of the rod.
I'm not the seller, I was just clarifying for others who may be interested and not mechanically inclined. To answer your question, or I guess your quirp, a spun bearing is nothing to be afraid of if you're mechanically inclined. A spun rod bearing, in no way, shape, or form poses a threat to the block if it's stopped early. But whatever, I've done my civic duty to inform the misinformed.
So yeah Bro, you're totally right. Mechanics is based on luck, and hoping on chance would be the much easier option vs. just taking the 30 minutes to take the head off and inspect it for yourself to see what you're buying.
