Mark this thread as Sold
>>> FS: BERK Header (HiperCoat Ceramic Coated) <<<
Never installed!
Asking $500obo shipped
[QUOTE]HPC HiperCoat Ceramic Coated Version (BT1615HPC) - These are coated on the INSIDE & OUTSIDE for the ultimate in thermal management.
Arguably the best performance/value header for S2000! Proven dyno gains!
SPECS:
True 50mm primary header
True 63.5mm exit
True SUS304 stainless steel, flanges, & tubing
True 1.6mm thick wall tubing (other usually have thinner walls = brittle/cracking etc.)
Silicon bronze welding rod at the flanges for ultimate fatigue resistance
Secondary wide band port for EMS tuning (plug included)
~11.5lbs (FYI stock is ~23lbs)
Our header will work best with a test pipe and/or a free flowing exhaust. Our test pipe mates perfectly to the header and utilizes the same 63.5mm diameter throughout. However, if you already have a 60mm test pipe from another manufacturer there isn
SPECS:
True 63.5mm exit
ViperASR
09-07-2012 05:35 PM
LostMotion
07-12-2007 09:00 AM
