Pm box - doesn't pop up
Hi Folks,
I hve had a couple of PM's tody sent to me, usually a message pops up in it's own box, saying message to read.
I do not seem to be getting the pop up box anymore? Does anyone else have this issue?
Kiwi
Kiwi
Administrator
Kiwi
Go here
https://www.s2ki.com/forums/index.ph...UserCP&CODE=04
Make sure you have YES selected on the appropriate option.
Make sure you have popup blockers off, or allowed for s2ki
Go here
I have checked this out as well.
The option is set to allow a pop-up window. However, even with the pop-up blocker switched off I still don't get the popup window.
Yes, it's been awhile since I've seen the popup notification.
The pop up notification went away when they did the redesign.. In the setup section, it still has the pop-up notification yes/no question, but it doesn't seem to be working..
Administrator
It works for me, it just pops up a normal browser window open to your PM inbox.
It's not supposed to do that but it doesn't matter because it's being replaced with a different sort of notification anyway. It will be fixed when I change the notification for new PMs.
Administrator
The new PM notification has been updated and it no longer pops up a window (it's pop-up blocker safe). It's now also less intrusive as it doesn't require that you do anything. You can simply ignore it and it will go away and it won't interfere with the page you are trying to read.
Hope you like it.
Hope you like it.
