pages are locked up
#28
using another browser... Still locks up
Error!
Connection closed by remote server
You tried to access the address https://www.s2ki.com/search/results?...ch%20forums..., which is currently unavailable. Please make sure that the Web address (URL) is correctly spelled and punctuated, then try reloading the page.
Make sure your Internet connection is active and check whether other applications that rely on the same connection are working.
Check that the setup of any Internet security software is correct and does not interfere with ordinary Web browsing.
If you are behind a firewall on a Local Area Network and think this may be causing problems, talk to your systems administrator.
Try pressing Alt+F12 on your keyboard and disabling proxy servers, unless you know that you are required to use a proxy to connect to the Internet. Reload the page.
Need help?
Error!
Need help?
#30
Seem like the system has a bug.... I've tried different browsers, same deal
Now at SEMA and it still happens
your post said you were going to update some software over the past weekend
I'm keeping you infomed, I was thing it was my system or browser .... not
I'm sure you also have a busy schedule during the day. often I post and it locks up right in the middle of posting. its bothersome to type up a thought and (ADD REPLY) and it locks up. Then I've got to find where I was retype and try to post again
Thank you for looking into thing issue, no hard feelings
