Air Con fix
Air Con fix
So my AC has not worked well for a few years, it won't hold gas and the AC rad looks fubar (in the standard car)
So I came to pull the bumper off
Many of the under tray clips are rusted and fubar so will get new ones, car is SORN
The drivers side arch screw also seized. It goes into a plastic captive thing which is no longer captive and just spins
Need to drill it out I guess, unless I can get pliers on with the wheel off and arch liner down
So not much progress lol
It looks not too bad behind there rust wise despite its early life being my daily a long time ago. Will be treating bits anyway to tidy things and future proof it
RYui (09-11-2024)
That was half the problem with my 06 - rust. Although the brakes were easy to work on and probably the fasteners were correctly changed a few years ago. I hate rusty stuff - had to cut the drop links off the front with the trusty Dremel. I refused to remove the rear bumper as I knew exactly what that would present me with - then you're knee deep in it forced to repair, as it won't go back on.
It's the only put-off from spunking 7 or 8 large on another S2k to save that needs my time to put right.
For the record only my W reg 20 years ago had a working cold air con - and it was crap - always went foggy and often blew steam out the vents!
The bottom clips were awkward, I had to remove the bumper at the top to get mole grips on them
The drivers side arch clip I took the wheel off to remove
Overall though not too much rust
This might be my issue
Slow going. Parts are proving hard to come by though honda have some at £500
Hmm.
Anyway meantime all the bolt off stuff I am removing and will probably get powder coated
This looks worse than it is
I'm bagging all the bits in labelled bags as it will be apart for some time I guess.. nothing to worry about in there except that condenser but the system has pressure still
Hmm.
Mine was diagnosed as leak on the condenser (bottom left) and the pipe running from there up to the drier. Your condenser looks like mine, although he did comment the fins dropping just impacts effectiveness, not gas pressure. That's usually the o-rings / fittings.
Advised to change both the condenser and drier. Chap did comment that the pipes love to crack when removing them, so best to soak them some penetrating fluid for a while before removing them. (Ideally replace the pipe, but they are not cheap for what they are)
At least the OEM o-rings are only a £1 a pop.
Nottm_S2 (10-03-2024)
The light brackets area right pita; I stripped, treated and painted mine recently only for the corresponding brackets on the bumper to scrape all the paint and treatment off as soon as I refitted the bumper.
