S2KI Honda S2000 Forums (https://www.s2ki.com/forums/)
-   San Diego S2000 Owners (https://www.s2ki.com/forums/san-diego-s2000-owners-152/)
-   -   now, im royally ***KED! (https://www.s2ki.com/forums/san-diego-s2000-owners-152/now-im-royally-%2A%2A%2Aked-305308/)
krazydave2000 07-15-2005 01:07 AM
Originally Posted by SIIK2NR,Jul 14 2005, 01:45 PM
How is that possible?...... did you miss shift? or overrev? That's the only way it could happen.
dude its the exact same thing that happen to alexs car. bent valve from over-revin( shift from 5 to 2) and both your cars are yellow weird. anyways good luck with your car- dave
R.P.M 07-15-2005 04:31 AM
Jon,
Check out what GDPzS2000 is selling. This may help you out, GOOD LUCK :thumbup: .
SoCal For Sale Thread
elude 07-15-2005 10:01 AM
thanks mike..
car is at another mechanical for a last opinion.. hopefully its not that bad..
damn, ive never misshift ever.. maybe bounced off the rev-limited but thats it..
god i hope i dont have to do an engine rebuild.
R.P.M 07-15-2005 11:23 AM
Call Group 5 and ask who they use. They did all of my b16 engine work and sent my head and block off somewhere in Miramar area. I got it back in my car and never had a worry again and a lot cheaper than honda or getting a new one. You just won't have your car for awhile. It will save you money though. They machined my head and block and my car never felt better. It turns out that the previous owner had over revved and ran the car when it was too hot burning up my pistons and causing my cylinders to misfire. He also ran my car on the lean side.
Good Luck :thumbup:
:hello: Patricia
elude 07-15-2005 11:27 AM
thanks patricia.. ill look into group 5 also..
gonna go pick up my car from the the shop, ill keep everyone posted.
Bigeggroll 07-15-2005 11:40 AM
$5000!!!! :eek3: man, correct me if i'm wrong, but can't u buy a used engine AND tranny for that much!! hmmmm, u can buy a cylinder head at majestic honda online for $2404.70. Check it out
http://www.hondaautomotiveparts.com/auto/j...ANSMISSION+ASSY.
Product No: 374097 (GENERAL ASSY., CYLINDER HEAD) $2404.70
l8,
jeff
elude 07-15-2005 02:16 PM
okay heres the update
compression low in cylinder 2. about 75psi lower..
bent valves..
so im looking around 2500-3000 in parts and labor to fix..
labor is the killer part.. hopefully i can work some deals around town...
hmm, might as well port & polish while im at it huh? :devil:
Choppa 07-15-2005 03:09 PM
If it is truly only in the head, and you want to build the head this is the perfect opportunity. You can find complete f20c's for around that or quite a bit cheaper (not including labor though :( ) Leakdown test should have confirmed if the problem was in the block or head (so obviously thats where they got their results from that it was the valves)
HFS S2K 07-15-2005 04:03 PM
Sorry John about the valves. Its wierd how I called it on Alex car and yours, to add to it they are both yellow! Good luck and be safe man.
Kind regards,
Joe
SYstem wheels?! PM ME
