Help on what kind of lowering springs I should get
what's the best lowering springs should i get? i don't want anything too low though...only want to drop at least an inch F & B. Thanks for your input in advanced.
peace
SOLE2K
peace
SOLE2K
Originally Posted by SOLE2K,Oct 10 2007, 11:27 PM
thanks bro...what's the pricing on those Skunk 2's? How are the TEIN S.TECH?
coilovers are also way easier to install
I've been on Eibach Pro-Kit springs for 3+ years. Gaps are as follows:
1/2 finger gap in the back
1 1/2 finger gap in the front
No rubbing, and you can run these with the OEM struts. I would recommend changing the struts at the same time if you can afford to, as the lower posture will wear out the struts eventually. However I rode on the Eibach/OEM strut setup for 50k miles before switching to Koni Yellows.
This combo is MUCH less expensive than coilovers, which are not necessary for 9/10th of the people that have them, IMHO. Sure if your gonna have a setting for track, for Auto-X, for the street, etc. and actually dial it up for each occasion then...sure. Otherwise it is just a blingin' waste.
Eibach Pro-Kit sells for $250 new and $150 used.
-Hockey
-Hockey
