Winter Washing - Salt Removal Tips.
Former Sponsor
Winter Car Care Tips - Salt Removal Wash
Helpful Winter Tips
Make sure the car is completely dry
This BMW 435 X Drive receives a salt removal wash and protect.
Salt Removal - Wash and Protect
Our special pre-soak was designed to chemically remove the majority of the salt and road grime off the paint, with our touch less approach we are preserving the condition of the paint.
After shot
Interior Mats - Salt Removal - just as important make sure your interior is free and clear of salt as it will cause long term damage to your interior bits and pieces.
Before
After
Helpful Winter Tips
- Keeping your vehicle as clean as possible during the winter will go a long way to cut down the damage done by salt and sand.
- Take your vehicle to the car wash as often as possible. If you can get to your undercarriage as well that would be a plus.
- Make sure to protect your car with your favorite wax or sealant.
- Carefully dry the edges of the doors inside and out, including the undersides of door handles, all hinges, plus the hood and trunk edges. This helps keep them from freezing shut.
- Use a good quality spray protectant on all exterior rubber or vinyl surfaces. It may be best to spray they applicator you are using instead of spraying the product directly onto the surface. This will avoid any overspray onto the paint.
After shot
Before
After
Helpful Winter Tips
After shot
Before
After
Helpful Winter Tips
After shot
Before
After
I'm very interested in a product, like you mentioned, is "touch-free" and is designed specifically to aid in removing salt+sand grime buildup before I wash with a regular car wash product with a sponge and bucket.
Fortunately I don't have to drive my S on any salt, I've just used my truck this week but my truck is also a very very clean looking vehicle (albeit it's 13 years old) with very good condition paint/body that I need something for - to help rid the salt and grime safely.
What products can you recommend?
Former Sponsor
jkelley,
check out post number 5 all the products are listed -
http://www.detailingbliss.com/topic/...n/#entry376266
The problem isn't the actual cleaning of the car as it is finding a day above freezing or a heated location to wash the car! Ugh. This winter has been brutal up in Connecticut.
detailersdomain
28
03-11-2015 04:17 AM
allkingz
11-25-2003 12:54 PM
