Windshield question
Windshield question
ive used Invisible glass for a while and black and white newspaper. but i have seen alot of pits on the glass or residue. any way to get this off? can you use a clay bar on glass? or is there anything else good to clean your windshield.
you can try clay... but glass polish is really your answer.
several out there- even zaino makes one.
easiest with the porter cable... always try it on a small area before going for the whole thing.
You should check out some of the new Diamondite glass refinishing products . . .
http://www.diamondite.com/
Haven't used any myself yet, but I've heard a few good reviews on them.
I apologize for 'ing an old thread but I have a similar question.
I have been doing some research on methods to restore windshields. Mine is pretty bad - over 130,xxx miles on the car - but no major cracks or chips that would really justify a replacement. Driving into the sun pretty much sucks, however.
I am aware of three different products that seem to be the "market leaders" - Zaino Z-12 Clear-View Glass Polish, Diamondite Glass Resurfacing Creme, and Eastwood's Glass Polishing Kit.
What I am wondering is if anyone has had any specific experience with these products. I have had someone local to me recommend the Zaino product but I get the feeling like it isn't, for want of a better term, strong enough for my issues.
I'm not looking for a miracle product here just something to give me some extra miles out of my windshield.
Thanks, in advance, for your input.
I've used the Eastwood product on several older car windshields (1930's to 60's) with excellent results. Take your time and follow the directions and you will take years/miles off your windshield.
http://www.eastwood.com/glass-polishing-kit-pro.html
I'm under the impression that Rhodite is serious stuff. Did you have any issues with cutting too much or ending up with waves?
I am guessing that better results, as with anything, are a matter of better technique, however. No matter what happens, it can't be any worse, right?
Rhodite is a serious silica product, but if you follow the instructions you will not have any problems. I keep a spray bottle of water handy while working the product with an orbital. It tends to dry out quickly and spreads better when slightly damp. Watch that you don't let the windshield surface get too hot when polishing, keep a light touch and let the orbital do the work. Check the worked surface frequently for smoothness using your finger nails, it should feel slick. Tape off your windshield and drape your hood and fenders to keep those areas clean. Good luck on the project.
Clean the area to be worked with vinegar/water mixture ( 1 tbsp/per quart).
