Will Clear Bra helps Headlight's hazzing ?
I was just wondering since our headlight will have a hazzing film after several years. i was thinking to put a clear bra on it to prevent it ? Will it helps ? Will it just slow the process or the lights will get hazzing no matter what ?
Thanks
Thanks
you can use plastx to prevent it from happening i dot it every month i apply plastx to my head lights by hand and clean them every week with plexus..
and to answer you question about clear bra i think it only helps for rock ships not hazzing
i don't have experience with the clear bra..but i don't think is meant for protecting the headlights from hazzing correct me if im wrong though.... from what i read around here its only meant for rock chips
The hazing I have seen is from small sand impacts along the lens edging...thats why you can use a PC to polish them off to clear them.
Here is a lens dehazing thread.
https://www.s2ki.com/forums/index.php?showtopic=296109
A clear bra is a must have on this front end especially around the headlight housings. A good installer will also have a bra type coating for the lens which will inhibit the hazing but even a bra will have it's own visual artifacts you have to cope with...
