why is plastiX so hard to find?
Old 10-06-2006, 02:06 PM
shotiable's Avatar
autozone/kragen has plastiX... isnt it from meguires? i'm not sure but i saw it in autozone. how do you get rid of the hazy headlights? what grade of sand paper did you use? i'm interested, i need to restore my mom's rav4 headlights. TIA
Old 10-06-2006, 08:31 PM
ProV1's Avatar
i'd like to know too. is sanding the headlight lens w/ 1000-1500 grit sandpaper required before applying plastiX? i applied plastix and rubbed it in real good today, but while the lenses came out better than before, i can still see micro scratches and haziness.
Old 10-06-2006, 08:35 PM
shotiable's Avatar
did you sand the inside or the outside? and maybe you should try 2000 grit sandpaper... its the finest sandpaper i could find. i used it for rubbing down my clearcoat. so plastiX kinda like rubbing compound for clear plastic surfaces?
Old 10-07-2006, 05:41 PM
KnowledgeIsPower's Avatar
autopia has plexus, also check motorcycle shops, every suzuki dealer in town has it there
if your really looking for plastx...ive seen that at autozone a long time ago
Old 10-08-2006, 08:01 AM
blurnj13's Avatar
Just went to an autozone and they had plastx (meguiars). I've also seen it at pepboys. I've used the stuff and wasn't happy with the results... plexus is almost as good. I would try the meguiars separate plastic cleaner and polish combo. Probably works better. (most marine stores carry the pair)
Old 10-08-2006, 03:19 PM
MikeyC's Avatar
Plast-X is actually more abrasive than the seperate Meguiar's plastic products.
Old 10-08-2006, 03:51 PM
blurnj13's Avatar
That sucks. I was hoping to pick up the separate and hopefully get some scratches out. I guess I'll have to PC it. When I took my car to get detailed 3 years ago when I didn't know how to detail, the kid (literally) who was detailing the interior was using some sort of glass polish on the plastic and scratched it up to all hell.
Since then using plexus and plastx, it cleared it up nicely and got rid of some of the scratches, but not all.
Old 10-08-2006, 06:57 PM
shotiable's Avatar
i feel ignored... no one answered my question of if its the outside or the inside that is supposed to be sanded in the headlight...
Old 10-08-2006, 10:45 PM
animeS2K's Avatar
definitely the outside. you shouldn't touch the inside at all, ever. It would entail breaking the seal, first off. Which you have to do if you're clearing your corners, but aside from that there should be no reason to open up your headlight.
And for the OP: I have a basically unused bottle of PlastX I'm selling for $3 + s/h... Maybe you could add it to some other detailing products I have for sale
See this thread:
https://www.s2ki.com/forums/index.ph...&f=47&t=424390
(Optimum products, Souveran, Meguiar's (#16!!!), lots of other goodies).
Old 10-09-2006, 01:23 PM
shotiable's Avatar
gotcha, will rub down outside of headlight with plastiX
e130dan
05-08-2011 03:19 PM
Project22a
06-21-2008 01:27 PM
jaehoppa
07-14-2007 02:55 PM
pikkashoe
07-21-2006 10:31 PM
1FastS2k
09-22-2001 12:48 PM
Quick Reply: why is plastiX so hard to find?
