Wheel well cleaning
Wheel well cleaning
hey guys, well I noticed my wheel wells were getting really dirty so I decided to take some tire sidewall cleaner foam stuff and spray under there and hope for the best. Anyway they look all dry and nasty still, what can I put on them to bring the black back?? TIA
check out our wheel cleaning thread...
to really clean the wheels, you gotta drop em off the car-
and thats the easiest way to get the wheel wells too!!
a long handled brush and car shampoo or an all in one cleaner will do pretty much what you need... and if you need more, i like p21s wheel cleaner (yup i know you are cleaning the well not the wheels, but it works)- only if you got really bad stuff in there do you need to go more aggresive.
most aggressive is an acid based cleaner- but i dont like using those, and especially not on brake hoses, etc. (you can, but make sure that they are rinsed first and are still wet when you use the cleaner- and do not let it dry)
from our how tos at the top of our board...
our wheel well cleaning thread:
https://www.s2ki.com/forums/index.php?showtopic=420668
I use either a dedicated tire cleaner or degreaser and an old wash mitt for my wheel wells. I then coat them with CD2 afterwards (you can buy this stuff from amazon.com). Makes them look like new and CD2 does a great job repelling dust/dirt
alrighty ill give it a try. I used a caned foam tire cleaner and figured that would get it clean enough, but it seemed as tho its not . Thanks for the advice guys ill give her a try!
