Wheel Shield? Or Similar Products
Originally Posted by FMINUS,Oct 24 2007, 10:15 PM
I use JS109 on the wheels. It doesnt prevent the dust from building but it does make cleaning a snap. Just rinse off.
I hope the Autobahn will keep the dust off for me. Its about $35 bucks for 50ml
Im going to try it over JS109 and see how it works. If this doesnt work, Im going to give up on wheel sealants.
I'm not bothered by dust build up on the rims; I just want to protect the rims from etching by brake dust and other dust etching into the metal. As long as the coating stays on and I can easily wipe/rinse off all the dust every once in a while I'll be happy.
diabolus2k ,
The question is do you want to replace clutches or brake pads? If you want to slow the car, sure you can use the engine, but brakes are much more effective, cheaper to replace, easier on the drivetrain bits, and less prone to overrevs (read replace engine). Wear particles from the brakes get on your wheels; wear particles from the engine swim around in the oil. The clutch dusts in the bell housing, which you won't have to worry about cleaning until you have to replace it (much sooner than you would if the brakes were used to slow the car though).
Seems like it's meant for the engine to accelerate the car, and the brakes to slow it.
I have polycharged detail spray I use on my wheels. Since I QD my car a lot it works best for me. I haven't had much luck getting any sealant or wax to be long lasting or much of a help getting brake dust off.
There a a few products (Dupont comes to mind) that contain Teflon which is the same stuff used for non- stick pots 'n pans.
It absolutly should work at eliminating any dust from adhering to the wheels which is not the same as dust "settleing" on your wheels.
Ideally, a blast from a high pressure hose will knock off the majority of dirt and dust.
The only question is- how well will it work and for how long?
Originally Posted by s98d7fs,Oct 25 2007, 06:45 AM
diabolus2k ,
Sorry for the OT post, just wanted to clear things up before people start thinking that engine braking is "bad" for the car...
If you aren't downshifting you aren't driving your car.
Even if you had an automatic, downshifting would also be automatic .When only using the brake the car would automatically select lower gearing appropiate for your speed..
[QUOTE=JackS,Oct 25 2007, 01:11 PM] There a a few products (Dupont comes to mind) that contain Teflon which is the same stuff used for non- stick pots 'n pans.
Originally Posted by Ubetit,Oct 25 2007, 11:57 AM
First it is not made by Dupont. A company called Tenneco licensed the Dupont and Teflon logo. You did exactly what the makers want your mind to do, make a leap of faith that because it contains Teflon, nothing will stick to it. Do a little reading on what it takes to get Teflon to bond... it's 680 degrees F
There's really nothing out there that will prevent brake dust from accumulating on your wheels. Waxes and sealants will help protect them and make the dust easier to clean off. The only way to truly prevent it is to buy a car that offers ceramic composite brakes (e.g. Porsche, Ferrari, etc.). They don't dust at all
It seems like JS109 does the job? I'll probably go pick some up and coat the rims.
