What polish should I use.....
I've seen excellent results with the 3M fine scratch remover so I'm thinking of using that on my car for removing light swirls. I'm going to be applying it with a polishing pad but before I apply the sealant i was thinking I about using this Menzerna Finishing Glaze (http://www.autogeek.net/menzerna-finishing-glaze.html)
would you guys recommend that or should I go with something else.
p.s. I was also thinking since my friend applied it with a polishing pad on a pc should I consider someother swirl remover if I'm using rotary? I'm not sure if the pc and rotary would have different effects with the 3M.
thanks in advance
thanks in advance
if you like the 3m remover, you might like their glaze too (i do)-
all of these products work with either the pc or rotary...
for dark cars (you can see i really like this stuff cause they have my car in the ad):
http://properautocare.com/3mperswirmar.html
some folks dont like glazes cause they have some fillers in them. i happen to like them, cause they give a bit more shine i think (oils that they use in the product).
if you already have the menzerna, its a good product too. its all opinion as to which is "best"
