What do u use on the Leather pices in ur S
Just wanted to see what u guys use for the interior pices in the S2000. On all the leather pices i need something been using just a microfiber towel for now. I want something that will clean it and protect it with out leaving a oily resadue over every thing else
leather is the only part that you need two separate products for interior:
you need a cleaner for leather- i like townsends cleaner, but its not easy to find... lexol also makes a good one
then you need a preservative- same as above... townsends is my fav, and lexol makes a decent one too.
a quality preservative will feed the leather and protect it too- sunscreen, and other protectants.
here- found the townsends:
i like the first two products (cleaner and protectant)
http://store.townsendleather.com/index.php
Originally Posted by espelirS2K,Jun 30 2009, 01:42 PM
I personally prefer Leather Masters. You can get the "trio" from DetailersDomain relatively inexpensively. It leaves an amazing finish/feel to the leather.
Do you plan on using it on any other car besides your CR? If not, I'd get the Rapid S cleaner (for regular leather), as it comes out as a foam already, instead of you having to foam it. And also it's a mild cleaner.
Also get the nubuck protectant (for suede/alcantara), vital and protection cream(for regular leather). Smaller sizes only--you don't need the larger sizes.
Aslo any idea on how long this will last, just a ball park figure. I would hope for around 3-6 months if i need every thing for the interior it would be around $130 so i hope this stuff does last and works as good as every one says
