well water stains on my windows
hey can someone recommend me a good window cleaner that will remove hard water/well water stains from glass. thanks
A spray bottle with a small amount of vinegar mixed with water should remove the water staining. Otherwise, you might have to resort to using a clay bar.
I would try glass cleaner or vinegar first. If not, then clay. Claying the glass is a good idea anyways, as it is the same as claying the paint.
If it does not work, let me know. There is a product that is almost last resort.
You could try Griot's garage glass polish:
http://www.griotsgarage.com/product/car+ca...Arrivals&page=1
I've been very happy with their other products, and while I haven't used the glass polish myself, my friend used it with great success on his Civic Si.
I had the hardest water spots on my glass for months (not on the S), I tried stoners then vinegar then I got medevil on it.
I used stoners as a lubricant and p21s cleaner on an old drill powered foam pad. I would have tried a clay bar, but i didn't have one and really, this stuff was like concrete. It came out perfect. I don't know if over time it may be too abrasive, but this time it worked great.
