Waxing Idiotic...
Waxing Idiotic...
It seems that when I remove whatever wax I have applied I end up with an uneven finish. From certain angles it looks like wax is still on the car no matter how much I take an MF towel to it.
Am I using too much wax? Is it because I am forced to work in the sunlight?
This also occurs with JW Acrylic Jett.
Sounds like too much wax. If you're in direct sunlight it's also probably drying too quickly. Try using Poor Boys wax. I've never used it, but it can be applied in direct sunlight.
If you were to place a 500 watt halogen 90 degree's to the finish, you could almost see a near microscopic scratch.
excellent info. Thanks.
Ambient temps go from 20F to 100F between winter and summer. I typically will wash and wax anywhere from 55F to 90F, above that is too hot.
I will try some QD next time.
And I do turn the towel and try not to push too hard
20F will make products freeze when it hits the surface. 100F, and your polish/wax will dry too quickly.
I find that certain products work very well in certain temps. A guess off the top of my head would be 60-80 degree's would be an ideal range. Some products that are more sensitive, may have a narrower temp range.
Sometimes detailing products can be finicky, but once you begin to master the art of detailing, you can manipulate the products to make them do what you want them to do.
even poorboys natty blue can sometimes dry a little fast in the sun (depending on temp, usually 90-100 degrees F)... The only product I've found so far that is easy to apply/remove in the sun is collinite 845. I can usually apply to whole car and buff off without any problems in the sun, but this is application via PC and buff by hand.
Originally Posted by RACER,Dec 14 2007, 06:39 AM
WoW!!!
