Vinyl top repair?
Vinyl top repair?
I just noticed today a slit in the top of my convertible top. It's about a half an inch long or so. I have no idea what caused it or exactly when it might have occurred.
Is it repairable? If yes, how? who?
My car is three years old.
Originally Posted by wanabe,Oct 3 2009, 11:46 AM
to get this thread started-
one of our members used this:
http://www.amazon.com/Permatex-81786-Super...r/dp/B000HBNT1O
it does the job, but be prepared to reapply every so often.
Before you attempt any repair, I would determine if it is covered under warranty or your dealer will 'good will' the repair.
You don't mention where the tear is but a number of owners have a tear due to improper finish of the soft-top frame.
This thread has the TSB scan and other relevant information. https://www.s2ki.com/forums/index.php?showtopic=701165
I sewed up the area first before I applied the kit. In addition, instead of buying a jean patch from Wal-Mart, I bought a waterproof nylon patch that can be applied without heat on the underside of the top. I used the same sealant to seal the nylon on the edges that was provided in the kit.
The repair worked well, but it still bugged me so right now I went ahead and purchased a hard top that will be installed shortly.
I took my car to the Honda dealer today and asked the service manager to take a look at the slit. I then suggested to him that it was covered by TSB #09-033. He printed out the TSB, read it through and without hesitation agreed that my car was covered. So I'm getting a new convertible top and two new handles! Yay!
Originally Posted by akimel,Oct 5 2009, 04:54 PM
Thank you for bringing the TSB to my attention!!!
I have been on S2KI for quite some time and the board has literally saved me hundreds of dollars. I'm glad I was able to help you out and 'pay it forward'.
See if you can find out if they do it in-house or out-source it to an upholstery shop. It is a real PITA to do the job correctly. They need to take apart a good portion of the interior/rear deck and trim before they can actually replace the top. You'll want to make sure they are sending it to a knowledgeable shop. You may want to post on your local board to see if anyone recommends a shop and see if the dealer will work with you.
Lastly, make sure they sand/file the burrs that caused the tear in the first place.
Good luck and make sure you put some protectant on after they do the work.
TokeMadBowls420
06-21-2006 08:29 AM
