Using MF bonnets with Edge Pads?
Quick question for the Edge 2000 users.... Are you guys putting the MF bonnets on top of one of the pads? Or, are you using a wool bonnet underneath?
Thanks!
Thanks!
Thanks!
Thanks!
A spare foam pad should also work out nicely. I was actually even thinking of using the white foam pad that comes with the PC and wrapping the bonnet around that. At least it'll make use of it.
Personally, I've never been a big fan of MF bonnets. However, on the rare occasion that I actually want to do product removal with the PC, I just put a MF towel under a foam pad and run the machine on 4. No need for a bonnet and no need to remove the adapter.
