Turtle Wax Ice with Detailer Spray
So after a wash, clay,cleaner and polishing, I finally got around to using this and I must say it aint bad. First off it's a synth wax that you can use in direct sunlight and on a hot surface. (although I didn't) It goes on clear and you let it dry to a haze. The best part is that it is meant to be applied to the plastic & rubber trim! Including the plastic lenses with no chalky residue. To apply it you use a moist applicator. And the other cool thing is when removing the wax it is recomended that you use the Ice detail spray while removing. Which is also clear and can be applied to the the trim as well. The luster is pretty amazing. I'm a fan of this stuff for now. Pics to follow. I Have to Apply carnuba on top tomorrow, do the interior and apply some Shin-Etsu. Stay tuned
Anyone else tried this?
