Stripping paint from aluminum.
Not sure if this is the right subforum to post this. Feel free to move if it isnt.
Does anyone know what product I can use to remove paint out of an intercooler? I tried acetone and it comes off easily, the problem is that when they painted it, the paint went almost 3/4-1" deep into the fins. I would like to soak it in some solution and them maybe wash it off, but not sure what to use.
The reason why I want to remove the paint is so that I can have it annodized. The annodizers did not want to do it as they said once they apply current, the painted parts will see a higher portion of the current going through them possibly eating up the aluminum.
See pics below, thanks. Joaquin
Originally Posted by GizmoIsChinese,Oct 24 2008, 12:16 AM
If the intercooler is symmetrical, you can just install it backwards?
NCSU, I know painting is an option but I rather not go that route.
I tried contacting KW to see if they can swap it out with me paying a fee, but getting through to them is like trying to call the whitehouse and expect Bush to pick up the phone.
Thanks for the suggestions,
Joaquin
dparm,
You are right !! I used that about 10 years ago to strip wheels ... I will pick some up on the way home and test it out.
I will keep you guys updated on whether it works out or not.
Joaquin
Joaquin
Originally Posted by dparm,Oct 24 2008, 07:37 AM
Aircraft remover. Available at any auto parts store...dissolves paint instantly, smells horrible, and will give you cancer if you inhale it. Great stuff.
I just picked up my black anodized IC today too. Anodizing is definitely a better way to go than painting.
A friend of mine got his done the same time and had to strip (previous) paint off. I brought it to a local metal stripping shop, they charge $40-$55.
I hope it works out in the end!
OK guys,
I spent a few hours this weekend stripping the paint using Aircraft Remover ... it worked 85%, and thats as much as I am willing to devote to this project ...
Tomorrow I am taking it again and having it annodized, if it gets a hole due to the paint left on it I will just buy another core and have the end-tanks rewelded to it.
Below are the pics and thanks for the suggestions. J
