Sonus SFX-2
Sonus SFX-2
My BB S2K has light swirl marks all over, and one place with heavy marks where I assume the previous owner was removing paint from where a door opened into the car and left a ding. Anyway, I plan to borrow a friends PC to apply a SMR, and I was wondering if SFX-2 would be enough to remove the swirls, or is this primarily a filler? I plan to use SFX-3 after, followed by AIO and P21S, probably all applied by hand unless SFX-3 would benefit greatly from application via the PC. Thanks
not positive, but my understanding is that the sfx-2 is not primarily a filler... in any case you would start with the sfx-2 first and then evaluate the job- if its done then you dont need the sfx-3. if you still see scratches then you go more aggressive. then i back down and would use the sfx-2 after, and finish up with the klasse and p21s... and i would give the klasse some time to cure before the p21s.
final step- take lotsa pics and postem up!!
yea but that means I have to buy both
I'll see if I can get a good picture today after work, then it will be easier to determine if I need to cut with SFX-1
