Sonax wheel cleaner turns brake caliper white
Anyone know other than painting the calipers a way to remove this white coating off the calipers? I've learned my lesson to probably not use this stuff unless the wheels are off the car.
I just re-use the normal shampoo (AutoGlym) that I'm washing the car for the wheels..
I wouldn't worry particularly for the colour of the calipers. Maybe it's time for a little DIY and some VHT paint?
Originally Posted by afzan
Sounds like you let it dry on there. Or your calipers were badly refinished I use sonax ALOT on my car for the past two years and haven't had any issues. It works great
I found that the sonax removes the contamination like it is suppose to. I take the wheels off once in a while and soak the calipers and brush them and they look "white" compared to before the wash. If you spray them and just let them be with only a rinse im sure you have just an uneven clean
