Seeing red...
Old 01-04-2004, 04:03 AM
tjohn's Avatar
Default Seeing red...
Why is it that when I rub on a coat of Zaino that I'm seeing red paint from my S on the applicator?
TJ
Old 01-04-2004, 06:50 AM
phoenix9999's Avatar
It's because your car is bleeding.
Old 01-04-2004, 07:41 AM
Ubetit's Avatar
Has your car ever been repainted?
Old 01-04-2004, 07:51 AM
wanabe's Avatar
tj- doesnt make sense... you should have sufficient clear coat so that you would not get any color from the car on your pad.
we need more info- like the answers to the above qs and are you the first owner of the car?
does it seem to just be in one spot?
Old 01-04-2004, 11:19 AM
tjohn's Avatar
Hmm, I don't think it's bleeding I'll have to ask it.
Not painted to my knowledge. I purchased it last summer new (as a left over) from a Honda dealer.
It seems to be coming off only on the hood.
Does this mean that the hood was somehow stripped of clear coat from something?
TJ
Old 01-05-2004, 06:20 AM
samjabori's Avatar
I use Zymol and am seeing blue on the applicator. Should I be concerned?
Old 01-05-2004, 06:27 AM
heffergm's Avatar
Only if your car is yellow.
Old 01-05-2004, 08:05 AM
Ubetit's Avatar
Traditionally you shouldn't see any color on a wax applicator after waxing a new car with a clear coat. Is this the first time this has happended? Do you regularly wax you car is this just an annual type thing?
Old 01-05-2004, 08:20 AM
tjohn's Avatar
[QUOTE]Originally posted by Ubetit
Old 01-05-2004, 11:16 AM
xviper's Avatar
When you say "rub", do you really mean you are applying a lot of pressure. If you are using lots of pressure, after 10 coats, I can imagine your clear coats are toast. Something like Zaino should not need any pressure at all to put on.
Quick Reply: Seeing red...
