S2000 Fender Emblems
Old 07-28-2008 | 08:06 PM
TheSpeedRacer's Avatar
Default S2000 Fender Emblems
Long story short, I just got my car back from the body shop (correcting another body shops bad paint work). Both fenders were repainted (the repaint job is flawless) but the S2000 emblems don't seem right.
Driver's Side
The S and 2000 seem too spaced out
Also, the S looks odd to me, is it upside down? lol
Is there supposed to be spacing between numbers? I remembered the numbers touching
HI RES
HI RES
Passanger Side
Again, the S and 2000 look too spaced out
Again, Is there supposed to be spacing between numbers? I remembered the numbers touching
And it looks kinda crooked
HI RES
HI RES
The spacing looks ok between the side marker and the emblem... it's just the S and 2000 that looks like they need to be closer. Kinda funny, the easiest part of the job and it's the only thing I can find something wrong with
What do you all think about the spacing? Do any of you know the exact placement if the emblems?
Old 07-28-2008 | 08:31 PM
RickIsYoDaddy's Avatar
drivers side does look upsidedown and it does seem a little far apart....
Old 07-28-2008 | 08:37 PM
haha so i'm not going crazy
Old 07-29-2008 | 06:19 AM
mattfeet's Avatar
They both look upside down and too far apart.
-matt
Old 07-29-2008 | 07:26 AM
wanabe's Avatar
my recollection is that the helms manual has the info-
let me see if i can find it and post it back here...
i took this after i replaced mine-
best way is to tape around the old ones... so you know where they go
cant do that with a repaint though!!
Old 07-29-2008 | 08:35 AM
wanabe's Avatar
very weird... i scanned the helms page with the info but it wont post-
it is on page 20-81 of the helms manual.
have scanned it and converted to both jpg and pdfs but neither will load as an image. not sure why...
Old 07-29-2008 | 08:49 AM
Thanks wanabe.... I need to order a Helms manual
Old 07-29-2008 | 10:18 AM
wanabe's Avatar
they have them here:
http://www.handaaccessories.com/s2000-04.html
Old 07-29-2008 | 01:34 PM
bcs's Avatar
bcs
I know i've seen a diagram somewhere that had the spacing for the emblems.
I'll see if I can find it...
**EDIT**
I couldn't find the one that I was thinking of, but I found a couple other things that might help.
This thread has a picture of the helms manual, but it doesn't look like you can click on the picture. At least I couldn't. It has the exact dimensions you need.
http://forums.s2ki.com/forums/index.php?s=&showtopic=171534
I found this one for the emblem replacement, but it is assuming that the original emblem is correct. But here it is anyway.
http://www.handa-accessories.com/S2000/s2kblkchrm.pdf
If I find that other one I am thinking of, I will post it.
Old 07-29-2008 | 03:32 PM
Thanks bcs, the pic in the fist diagram shows the spacing perfectly... I'll just go back to the body shop and ask for new emblems, but I'll install them myself
Quick Reply: S2000 Fender Emblems
