rusty brake discs?
rusty brake discs?
What's up with that?? The slightest amount of water will make my discs rust up.
A: is that normal?
B: can I treat the discs with something to protect them??
thx!
A: is that normal?
thx!
So you're saying that it's not going to screw anything up in the long run??? I am a mechanical idiot, so forgive my ignorant questions!!
thx
thx
The rust comes off as soon as you use your brakes again... its just a powdery substance on the surface.
They rust because they're iron! You can't coat them because the friction will wear away the coating.
Ricks2k.com is working on/has stainless steel rotors coming out for our car... apparently they work rather well.
Originally posted by jeffbrig
What I really hate are the spots where the rusty drips from the discs dry on the inside of the wheel.
Yeah, the gunk comes off pretty easy if I can get my hand to it - comes right off. I need to invest in some sort of brush to get back where I can't reach....
The only way to prevent rust is to get a rotor that is made out of something that doesn't! For us w/ OEM rotors, a little G2 paint on the inside and some RejeX on the wheel works really well.
Autogeek.net
10-12-2013 11:03 AM
