Rotor cleaning
Rotor cleaning
Hey guys I was cleaning the rust off my wheel hub yesterday with naval jelly I got some on the rotor and now there is stains that I cant remove. What do you guys recommend I use to take the stains off?
wonder if this will help- our how to clean rotors:
https://www.s2ki.com/forums/index.php?showtopic=227069
also wonder if some brakeklean might do the trick.
suggest that you test the back side first. and be very careful to remove all product well.
btw, be sure to "break-in" your brakes after this... meaning drive slowly with brakes on to be sure that they are dry and are working well.
be sure not to get any acid on the brake pads.
i dont want to read that you got the rust off and then went for a spirted drive, but brakes didnt stop the car !!
Autogeek.net
10-12-2013 11:03 AM
