Is this the right order?
Ok now i'm just waiting for my Zaino Z1, Z2, Z4, Z5. Now correct me if i'm wrong
Step one wash and soap my S with Dawn.
Step two use Z1
Step three use Z2
Step four use Z5?
Correct me if i'm wrong thank ya'll
Step two use Z1
Step three use Z2
Step four use Z5?
Firstly, I don't believe there is a Z4. Z5 is the swirl and scratch remover. After you use the dawn, I thought you are to use the Z5 until you are happy with the how the swirls and scratches went away. Then you would use:
Z1, Z2, Z6, Z2, Z6, Z2, Z6. Then you can use Z7 to wash in between more Z6 and Z2. Whew!
Also, check the Zaino web site for all their tips and answers to the FAQ's. This info is very valuable.
1)Dawn.
2)Z1
3)Z2 or Z5
4)Z6
5)repeat 3 and 4 until satisfied.
You can alternate Z2 and Z5 or you can just use Z5 until your satisfied with the staus of swirls then move to Z2
2)Z1
3)Z2 or Z5
4)Z6
Make sure you wait between every coat of Z2/5 for them to cure. 6 hours if above 70 degrees and 24 hours if below 70 degrees. Otherwise you will not enjoy the layering effect Zaino has.
Make sure you use them as the directions state (very thin). Post if you have any more questions.
