Removing wax w/ bonnet
Old 01-03-2008 | 09:34 PM
Sanguine's Avatar
Default Removing wax w/ bonnet
How many members here apply wax with a PC then use a bonnet for removal? The reason I ask is anytime I tried to use the bonnet it doesn't do a good job removing the paint. I may be putting too much wax on the car because after awhile the bonnet just gets caked and cannot pick up anymore. I end up switching over to an MF towel to remove the remaining wax. Anyone have tips here for quick wax removal?
Old 01-03-2008 | 09:46 PM
RACER's Avatar
Once the bonnet get caked, it picks up less and less product. Being the bonnets are so expensive, I use them for a final buff. I use microfiber hand towels for removing the bulk of wax/polish, then use a microfiber bonnet for the final buff.
Old 01-03-2008 | 09:59 PM
wanabe's Avatar
i sometimes apply with a pad, then remove with a lambswool pad covered by an mf bonnet. sometimes takes more than one bonnet if it cakes.
does sound like you have too much wax on the car- i like the pc for applying cause you can keep the layer really thin. you should barely see the wax when its the right thickness... synthetics are the same.
Old 01-04-2008 | 12:15 PM
Sabre's Avatar
I agree with the above. I really dont like using the PC/Bonnet for removal. It just...feels more time consuming because of how it eventually cakes and such. I much prefer using a couple of buffing towels and call it good. I like being right down at the surface so I can see the shine start to appear as I remove the haze too.
Old 01-04-2008 | 01:45 PM
krshultz's Avatar
I've never tried it myself. I wax with zymol Carbon, which mandates that you remove it while it's still wet - so the PC would actually be a bit of a kludge for this application. Removing zymol is *so* easy that I never really found myself wishing the PC was effective.
slanguage
07-14-2008 09:59 PM
dtmcnamara
03-19-2008 04:10 PM
slanguage
06-07-2007 05:49 AM
dmw16
03-03-2007 08:03 AM
notyourfriend
02-15-2007 08:19 AM
