removing wax in between panels?
been getting a lot more into washing my car lately and one of the main issues i have been having is how to remove wax from the small cracks in between panels and in places like around the door handles on my car. so far all ive come up with is trying (unsuccessfully) to stuff a microfiber cloth into the cracks as best i can. this works in some areas but is terrible in others. i never see wax residue on show cars or in the detailing posts i see on these forums. whats the trick?
I've used this product or one similar for years with excellent results. They can reach into those small/narrow areas to remove or clean and work well dry or wet.
http://www.griotsgarage.com/product/...urPicks&page=4
To get it out I use either a toothpick, a bunched up microfiber cloth or some rubbing alcohol. The alcohol needs a cleanup after, and will also remove other waxes to be sure to start masking your car if you want to prevent more wax from getting in the gaps.
I use a toothpick and or a toothbrush.
If you're constantly getting wax build up in between the cracks you're using way to much product. Next time you wax your car use an amount that is so small you wouldn't think it would be enough. Try spreading that around a body panel and see if you can get complete coverage. You should easily be able to avoid filling the body gaps with product.
If it's dried wax that has been there forever then an all-purpose cleaner on q-tips will work.
The trick is not letting it dry and build up in the cracks. While you're waxing use the tips mentioned above and also run your microfiber towel down the cracks. That way if you do get some in there it will wipe right off.
thanks for all the tips guys. i think i have definitely been using too much wax. i used the credit card method and it works well on most of the gaps, but some of them are just too narrow for the card+microfiber to fit. gonna give the brushes and toothpick a try next, but im thinking i should prolly just remove the current coat of wax and redo the whole thing using less so that i dont have this problem to begin with.
