Removing "s2000" emblem on fenders...
#21
I used GOOFOFF then polished and waxed, up close you can see like an indentation of where the badge was, kinda annoying, I also chipped the paint when I took it off, bastards
took 30 minutes
took 30 minutes
#22
Used a Blow Dryer about 5-6 inches away from the emblem. Let it heat up, then used the fishing line method. Goo Gone to remove the adhesive. Wash/Wax afterward to remove finger prints and to calm my OCD about a clean car.
#24
took 30 minutes
took 30 minutes
#26
Wait for a nice hot day, use waxed dental floss (stronger that fishing line) and make sure that you use the floss to cut the foam as close to the actual emblem itself not the body of the car, do use the floss against the paint it may leave scratches. I would take some simple green/goo gone or other degreaser and spray it on the emblem (soak it really good) and let it set for at least 15 minutes, then use the floss on it. Once you get the emblem itself off, then you can use more goo gone on the foam adhesive part that is left behind. Take your time, I don't recommend using gasoline, GOOF off, or any other harsh chemicals, go for a water based degreaser.
#27
I just finished! Hott-damn it took me a good 45 minutes! I used fishing line and my fingernail/Goo crap. I didn't finish it up with a clay bar or waxing or anything... just RUBBED with the cloth until my finger was literally rubbed my finger bright red-ha. I can't even tell that the emblems were ever even there... so all in all, it looks hella-good now. Thanks everybody-
#29
Originally Posted by Snowmoto125,May 21 2009, 11:37 AM
I used go gone, with a hair dyer and my finger nails. Took forever, and snapped a lot of dental floss but I love the outcome of it
Adhesive remover helped with the foamy stuff, but it took a lot of elbow grease to get it all off. Clay time (hoping that gets rid of the "shadow" from the badges)
