removing emblem tape?
hey guys i just removed my s2000 emblems off both sides of the car and there is still alot of tape stuck to the fender....any suggestions best and easiest way to remove the tape with out damaging the fender or paint???
thanks in advance
thanks in advance
Originally Posted by mzvyap2,Jan 6 2010, 07:44 PM
I used dremel tool w/ polish head took all the dried sticky tape off in less than 3 min on each fender. Fast, easy and effective
3M Adhesive remover will take that tape off no problem without risk of removing the paint as well. You can find it in most hardware stores and many auto parts stores.
Originally Posted by MikeyC,Jan 6 2010, 06:03 PM
Wow! I imagine you could easily take off the paint with the adhesive.
about the side emblem,.. they only stick to the car with a tape??? how bout the front and back emblem??? planning to de badge my car, tried to do it with my old teg turns out that the front is like bolted,...
Sides are only on there with some tape. I took about half an hour each side with a credit card and a can of pb blaster. It was a PITA but so worth it. The trunk and hood emblem will leave holes behind them.
