recommendation on wheel cleaner
hey guys I just want to get a recommendation on what claener to use on my wheels. Its chrome but it has a clear coat over it. what would you experts suggest i use since its clearcoated. also would it be best to wax it also? thanks for the help!
I really like the DP gel wheel cleaner. It works great on my clearcoat wheels. I also use Chemical Guys JS109 sealant on my wheels. Nothing seems to last very long on the wheels, but the JetSeal makes it almost a spray away type of cleaning every week.
Nice wheels, btw.
Nice wheels, btw.
i like p21s- usually just use regular shampoo with a wheel brush... if its stubborn, i like the p21s wheel cleaner- non-acidic and does a great job.
and agree with ebeldesign that a good synthetic (as many coats as you can stand- at least two) is a great idea... i always do synthetic on my wheels and often top it with carnauba.
i also have a duster for wheels only. dust the wheels whenever i see any dust, and then hit them with a detail spray with either carnauba or synthetic in it (depending on my mood!).
the heat of the wheels will evaporate protectants more quickly than on the paint- one reason that i use a detail spray with more stuff in it... kinda protect the protectant!!
Nice wheels, btw.
Nice wheels, btw.
If you wax/seal your wheels, be aware that a wheel cleaner will likely remove the protection. So, after you've cleaned/waxed/sealed your wheels, I'd suggest keeping them clean with car wash soap rather than a strong wheel cleaner to prevent stripping. Regular maintenance will prevent you from having to use a wheel cleaner every time you wash.
Originally Posted by Sinji,Feb 27 2008, 10:25 AM
thanks guys.
ben, can you tell me where i can get the gel and sealant locally in OC?
Like I stated on another thread:
Amazing Roll Off is simply......well... Amazing!
BTW, the PH balance is neutral
Originally developed for boaters to clean canvas sails, Amazing Roll-Off works wonders on cleaning vinyl and canvas convertible tops. Even tough stains that other cleaners can't touch come out with little or no effort. Roll-Off will not degrade the water repellency of convertible tops.
Plus a whole lot more!
1. It's a clearcoat safe, 100% acid-free wheel cleaner. Spray on Amazing Roll-Off and watch as caked-on road grime and brake dust wash away!
2. It's a powerful tire cleaner. You'll be amazed as brown sludge slides off your tires.
3. It's a white-wall cleaner. Roll-Off brightens white-walls and raised white letters. Without bleach! Roll-Off will not discolor the carbon black in tires.
4. It's a vinyl top cleaner. Amazing Roll-Off easily removes layers of sun-baked grime that other cleaners can't touch.
5. It's a convertible top cleaner. Amazing Roll-Off safely cleans grease and dirt off canvas and vinyl convertible tops without harming water repellency.
6. It's an engine degreaser and brightener. Amazing Roll-Off cuts the toughest grease, oil and diesel soot and brightens aluminum engine parts.
7. It's a fiberglass cleaner. Those tough, black stains on the side of RV's wash off with ease. You can even use Amazing Roll-Off to clean the vinyl siding on your home!
Note: Amazing Roll-Off works wonders on mildew! Wash mildew off your boat in minutes, even if it has been there for weeks. Keep mildew at bay with regular washings with Roll-Off!
It's fast! It's easy! It's safe!
Amazing Roll-Off is a concentrated, water-activated cleaner. Simply wet the area to be cleaned with water, spray on Amazing Roll-Off and rinse the dirt and grime away. Roll-Off will amaze you with its cleaning power. Dirt that other cleaners can't touch simply rolls off with little or no scrubbing. Amazing Roll-Off is bio-degradable, non-corrosive, rust inhibiting and ecologically safe.
Plus, a bonus!
Amazing Roll-Off leaves a gleaming and rust inhibiting wax-like finish that resists dirt. Surfaces remain clean longer. Future cleaning is easier, takes less time and can be done less often.
Plus, a bonus!
Former Sponsor
I've posted pictures of my wheel refinishing project elsewhere as well.... but it applies here. Basically, P21S gel is incredible. Here's a shot of a wheel after P21S compared to before. Keep in mind, that harsh solvents like simplegreen and a scrubbing pad wouldn't even get this crap off. P21S sat untouched for 2 hours and then wiped off. The stuff is awesome.
Phil at Detailer's Domain is the man too btw.
