RavynX's Detail Log
I have one or two of those little spots on my trunk your talking about and I read that tree sap can cause that. I parked under a tree for a year before I moved and got a garage so I think that's what did it. My old accord was the same way parking it under a tree
Ah!! I can't wait to do my detail. I have the exact same PC and polishes (even the Adam's detail spray ) that you have except I have Blackfire sealant. Too bad I won't have nearly the same results as you as I've heard GPW doesn't have a particular "wet" look
Good job. A way to reduce the splatter is to
1: Apply your product to the pad.
2: put your Pad/Polisher on the car where you want to work
3: BEFORE turning on your polisher smear your product around the area you will be working.
4: Start on a slow speed (2 works best with the pc)
5: Move on to high speed.
No splatter.
You know some people believe that even power washers (personal, and the ones in the wash bays) produce swirls or micro marring, because they force the dirt off the car with so much pressure, that they leave scratch trails.
As far as the "imperfections" it's probably either water or bird etchings. Really takes some time in those ares that have those imperfections to remove them. Use your stronger combination, then move to something less aggressive to bring more clarity to the paint.
No splatter.
My compliments on the care you are giving your Stewie. You have obviously done your homework. I'm impressed by the way your taped up the trim and lights and covered the convertible top, etc. You're on the way to becoming a master detailer!
I also have hard water in our area and our cars pay the price with water spots; consequently, except when using ONR, I always go over the paint with a quick detailer after a wash and dry, except when I intend to clean and wax the paint immediately afterwards. Some folks like to use a quick detailer as a drying aid, which also solves the water spot problem. For some reason, I prefer to dry first and then go back over with the quick detailer.
No splatter.
No splatter.
I also thought the same thing about power washers, even using home-units. That's why I spray the car down first now, then use the 2 bucket system with a lambswool mit. :thumbsup:
Ahh yes, pulling the polisher up while it's still on. You'll get used to it! Keep working at it. Maybe you could try 4" pads for the "imperfection" areas.
s2kdriver80
09-29-2003 09:14 PM
