A Quick Zaino Question
Ok.....two really
First, can I apply a ZFX coat over the traditional Z-1/Z-2 finish that I have now or will I have to remove the older Zaino coat first?
I have a faint sweeping scratch on the hood about 1.5 feet long. I think it may be from a particle or something that got trapped on the Water Blade (will always rinse now ). You have to be at an angle to see it.
Is this what Z-5 Polish for Swirl Marks & Fine Scratches is made for and how do you rate it?
Thanks guys
Thanks guys
Yes, you can use the ZFX over the Z-1/Z-2. No need to remove the existing Zaino.
The Z-5 hides minor scratches and swirls for the life of the polish, about six months. It may take one or two coats or five or six coats, depending on the scratch or swirl. If it's a scratch that you can "catch" with your fingernail, then an abrasive would be necessary. But if the scratch is only seen at an angle, the Z-5 should take care of it.
