Quick Detailing Spray
most quick detailers sprays use synthetics...
the synthetic that i usually use over carnuba is zaino.
it does not seem to effect the carnuba base.
you can also use a carnuba based spray.
griots makes one that i like, and cant remember for sure, but think that meguiars quick detailing spray might also contatin carnuba-
anyone know?
anyone know?
1 Post
I like Meguiar's Final Inspection. It contains no silicones or carnuba which is what you want if you layer with some type of polymer/synthetic. Otherwise it prevents "bonding."
I hear good things about Zaino's QD and Clearkote's QD.
Things to look for:
1. Price
2. Ease of use (some streak more easily, some don't)
3. What the QD contains - Carnuba, Silicones, etc. (depends on what you want).
4. Some products you can apply in the sun, some others you do not want to (I don't like Quick Detailing on hot surfaces though).
Find what you like and buy a gallon of it. The price is significantly cheaper.
For example, 1 gallon = 128 fl. oz..
1 bottle (16 oz.) of Final Inspection will cost you $6.99. 1 Gallon will cost you about $22. 8 bottles
@ 6.99 would make 1 galloon. That's 42 bucks! On the other hand, I tend to use a lot more FI when I have a gallon sitting around.
Things to look for:
1. Price
1 Post
anyone know?
anyone know?
Meguiar's Final Inspection contains no carnuba.
Meguiar's Final Detail (pink) contains silicones.
FYI - Rumor is Meguiar's Final Detail is being replaced shortly with ["Last Touch - Meguiar's Last Touch Spray Detailer produces incredible depth, shine and gloss. This spray-on, wipe-off product has a unique blend of polymeric lubricating agents that gently removes dust, fingerprints, smudges and other contaminates, leaving a flawless, showroom shine."
Originally posted by SolReborn
Is this the same stuff you use for both lubricating your clay bar and for a quick cleaning inbetween waxing?
1 Post
oc s2k-
you reminded me...
zaino's is not easy to use (until you get used to it).
griots is pretty easy to use.
oc s2k-
you reminded me...
don't waist your money using a QD as a lubricant for clay - simply mix some car washing soap with water (i use 50/50) and spay the mixture on the car, clay the area, then wash when you're done..
