Proper care of Microfiber towels
If i recall someone said that a tiny bit of vinegar in my microfiber only batch of laundry should do the trick in keeping my towels for a long time.. anyone got useful input on this?? tHanks.
Fabric softener can clog the pores in the MFs and make them less absorbent. Half a cup of vinegar in the rinse cycle helps. Ask me how I know.
I'd like to hear from people who tried products that were specifically designed to clean MFs. I'm interested in buying something like this if they give better results than the vinegar method.
I use 2 oz of plain old white vinegar per load. A gallon last a long time at that rate. Maybe 6-8 towels a load. My towels are fairly new, less than a year, and show no ill effects at this point. It seems to work fine and it's know that vinegar helps remove soap build up from fabric so you might as well extenf the life of you MF's by using.
I use the vinegar method also. If your washer has the fabric softener thing in the middle of the agitator (on top), put it in there. It will add it to the rinse cycle itself. Tumble dry low heat, with NO fabric sheet. The softener gives the microfiber a weird feel, and can leave streaks on glass, and your paint. I just ordered some microfiber detergent form autogeek.net. Once I try it, I will let you guys know how it is, and if it works well enough to see a difference, I will post up a couple of pics
I think it will be a good investment considering I just bought some more microfiber, getting some more in a couple of days, and buying some microfiber drying towels in the future
Roger
Roger
Cold water wash with woolite or dreft, sometimes i use vinegar in the rinse. Don't use high heat in the dryer, only the delicate cycle. If your towels get too hot the split fibers will fuse back together and they won't work.
Originally Posted by wanabe,May 31 2007, 12:32 PM
i use the sonus mf shampoo... wunder wasche or something like that-
leaves them nice and soft!!
As for softener, all the towels warn not to use it. I ended up just air drying the towels on a rack. They still ended up soft.
