PC on rear plastic window?
I just bought my 00 Berlina and, like most, it has a hazey rear window. I've already tried applying some of this PlastX that I bought to the window, both on the inside and out, and it seems to help a little but not enough. Has anyone tried taking the porter cable to the window? Would it help at all?
Thanks!
edit: Also, does anyone recommend anything besides this Meguiars stuff? I have Plexus but I don't know if that'll help more than the plastx would...
Thanks!
i used novus on mine and it worked great. The only problem is you can't apply alot of pressure to the back window because it will stretch the plastic and that will cause it to bend wrong and eventually it will crack the plastic.
yep by hand. I put just a little bit on a good towel and gently and slowly applied it just like i was waxing the car, just softly enough not to stretch the plastic. I keep going in circles and do one little area at a time. Then u can use a paper towel or something and go over it gently and wipe it off. Do this to the inside and out. Just dont use alot at a time.
