"old zaino" question
copy of pm-
my reply is first then the question- am posting cause its a good question and others might have other thoughts:
if your zaino has not seen high heat or freezing temps (extremes), it is likely o.k.-
shake it really well. if it stays combined go for it...
and if you are worried at all, just do a lower part to start with, as a test.
i really think you are fine. and if you want, you can use that griot's wax to top the zaino! just make sure that the zaino cures before topping- i would give it some extra time.
you should have posted this up, cause its a good question.
i will copy it and post it for you.
[QUOTE]Hi,
I've been using Griot's Best of Show Wax and thinking of going back to Zaino.
[QUOTE]Hi,
