A noob with an s2k!
A noob with an s2k!
so fellow s2ki members, im about ready to put my s2k on the road but theres something that's bothering me....
it looks like paint, but how do i get it out?!!? and how do i get it out if it's on my softtop?
thanks a lot guys, also another question, someone suggested the s2k is slammed, what do u guys thinK?
here are some more pix, thanks again
mmm.. buffed
mmm.. buffed
does look like its dropped a bit- not a lot, which makes me guess eibach pros...
and clay is your friend for the paint solution- clay was first used for paint overspray in paint shops... it works on dry paint too.
as for your top, you have a challenge cause anything strong enough to get paint off of vinyl can melt the vinyl too.
let us know whether you really have paint on the top and we will give you some choices...
more clay info:
http://properautocare.com/claybars1.html
more clay info:
thanks wanabe
the springs look regularblack to me, i did notice a litle bit of bouncing on the way home, i hope they're not cut. i havent been able to acutally park beside a stock s2k to compare it....
as for the clay, i'll definitly check it out, can i use a blade on my glass?
Originally Posted by drshoelaces,May 30 2007, 07:05 PM
thanks wanabe
i assume you mean a razor blade- the answer is yes...
but test first in a small area, and be careful not to damage any rubber around the edges
try the clay first-
Are you talking about the white stuff everywhere? If so, that looks more like compound to me. If so, it will come off pretty easily. I often use Poorboys Spray & Wipe to safely remove that stuff. Assuming I am looking at the wrong thing in the pictures, I try to avoid razor blades on glass where I can. If you get something stuck in the blade or have a bad spot on the blade you can do some damage. Before going to the blade, I usually try goo remover. This is what I used to get the sticker residue and plastic cover residue off of my 2007.
-GT
-GT
turbosix
28
09-23-2008 08:29 AM
