Need a Little help with which order to use this stuff
So, I am in need of a little help figuring out which order to use all of these products. I have the Porter Cable 7424 and i bought all of this stuff with it about 2 and a half years ago, but i have no idea which order I am supposed to use this stuff anymore. Also, any help as far as which pads i need to order for each product would be greatly appreciated. I left my S2000 in the care of my father for the time I was out of state, which was about 2 years, and never wrote down which order i was using this stuff. Thanks in advance for the help. Below is a list of Products I have.
1)Menzerna Polish PO106
2)Menzerna Finishing Polish PO115C
3)Menzerna Intensive Polish
I also have some Einszett wax and i am assuming that comes last, but I was wondering which pad i should use when applying the wax as well. Thanks so much for all of your help
Intensive Polish on an Orange Green/White Pad moderate to high speed
PO106 on an Green/White or Blue Pad moderate to high speed
115C is glaze so I would say Black Pad low speed
Einszett Black pad low speed.
Seeing a BB in your sig.. Be prepared the paint is quite soft and prone to marring during correction. You may need to work out the best process to finish down using the 106 and may need less speed and a longer polish to break down the polish even farther then usual as a 3rd pass. Nice soft MF towels are key too.
Former Sponsor
you will want to
wash ---> clay ---> ip with an uber orange or yellow pad --> po106 with uber green pad --> use 115 with a blue pad if but you can skip the step.... finish with glanz wax with an uber black pad.
TheSpeedRacer
08-12-2008 12:37 AM
